Simple angular momentum problem. QM
armis
Show that Lx is a Hermitian operator
Well, since Lx is an observable it must be represented by an Hermitian operator.
L = -i\cdot\hbar\cdotr\times\nabla
If an operator is Hermitian, then it's equal to it's Hermitian conjugate
I do realize what I have to do, however there are holes in my math.
So in order to show that the Lx operator is Hermitian I could show that:
< L_{x} f | f > = < f | L_{x} f > is that correct?
If I assume that's correct and since < L_{x} f | f > = (< f | L_{x} f >)^* I have a complex conjugate missing somewhere. Thus there is an error
You don't have a conjugate missing, the identity on the last line is true.
The point is that, by definition of Hermitian conjugate, if you want,
\langle f \mid L_x f \rangle = \langle L_x^\dagger f \mid f \rangle
so if you show that it's also \langle L_x f \mid f \rangle then effectively you are showing that L_x^\dagger = L_x.
Thanks. That I understand but I probably don't understand something else or I don't really understand either, anyway to be more specific here is what I mean
\langle f \mid L_{x} f \rangle which is
<f|-ih(y*d/dz - z*d/dy)f>. (I am sorry, Latex doesn't show up for this one. I guess I typed it wrong)
now if L_{x} is Hermitian then as far as I can understand the above expression must be equal to
\langle L_{x} f \mid f \rangle which is \langle f \mid L_{x}f \rangle^*
and here is my problem, I get that \langle L_{x} f \mid f \rangle is equal to \langle f \mid L_{x} f \rangle conjugated and because of the i in the L_{x} expression the two don't really match, do they? :confused: What am I missing?
Just to be absolutely clear I don't like the fact that <br /> \langle L_{x} f \mid f \rangle is <-ih(y*d/dz - z*d/dy)f|f> doesn't seem to match with <f|-ih(y*d/dz - z*d/dy)f>
you can give a proof of this since the L_x operator is = y*p_z - z*p_y
now you proove that x_ip_j is hermitian. i.e show that
\int ( x_i\hat{p}_j \phi)^*\psi d^3r = \int \phi ^*x_i\hat{p}_j\psi d^3r
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
