How Do You Solve This NH3 and H2O Chemical Equilibrium Problem?
  • Thread starter TheManw/theGoldenGun
  • Tags
    Chemistry
E-4 M, % ionization = ([NH4+]/0.0180)*100% = 3.11%e. a. 30.0 mLb. pH = 9.27c. pH = 2.70In summary, the conversation discusses the reaction at STP between NH3 and H2O, and provides equations and calculations for finding the Keq expression, pH of NH3 solution, Kb for NH3, % ionization of NH3, and pH of a solution after the addition of HCl. The conversation also includes a question for clarification.
Hi all, this is the question:
Question data:
Reaction at STP: NH3 (aq) + H2O (l)  NH4+ (aq) + OH- (aq)
[NH3] = 0.0180 M
[OH-] = 5.6E-4 M
The answers I tried are in blue.
a. Write Keq expression for reaction above.
Keq = ([NH4][OH-])/([NH3][H2O])
b. Find pH of 0.0180 M NH3.
Do I use the Henderson Hasselbach equation for this? pH = pKa + log(Base/Acid)? =
c. Find Kb for NH3.
Kb = Kw/Ka right? How do I find Ka then?
d. Find % ionization of NH3 in 0.0180 M NH3.
I guess this is [NH4+]/0.0180*100% right? How do I find NH4?
e. 20.0 mL of 0.0180 M NH3 was titrated beyond equivalence point using 0.0120 M HCl.
a. Find volume of 0.0120 M HCl added to reach equivalence point.
So this happens when moles NH3 = mol HCl. So, 0.0180 M NH3 * .020 L = .00036 mol NH3. We would then need .00036 mol HCl, which could be obtained from doing .00036/.0120 = .030 L or 30.0 mL, yes?
b. Find pH of total solution after 15.0 mL of 0.0120 M HCl was added.
.015 L * .012 M HCl = .00018 mol HCl reacting with .00036 mol NH3 in 0.035 total L solution...do I use Henderson-Hasselbach for this too?
c. Find pH of total solution after 40.0 mL of 0.0120 M HCl was added.
Since you have .04 L * .012 M HCl = .00048 mol HCl reacting with .00036 mol NH3, you have .00012 mol worth of excess H+, divided by total solution of 0.06 L = .002 M, take -log(.002) = 2.70 = pH? Yes?
Help please!
a. true
b. true
c. Kb = [NH4+]*[OH-]/[NH3], [NH4+] = [OH-], [H2O] doesn't goes in equation, because concentracion of water is constant, 55.555...mol/dm3
d. [NH4+] = [OH-]
a. Yes, the Keq expression for this reaction would be: Keq = ([NH4+][OH-])/([NH3][H2O])
b. Yes, you can use the Henderson-Hasselbach equation to find the pH of 0.0180 M NH3. The pKa for NH4+ is 9.25, so the pH would be: pH = 9.25 + log(0.0180/0.0180) = 9.25.
c. To find Kb for NH3, you can use the relationship: Kb = Kw/Ka. The Ka for NH4+ is 5.6E-10, so the Kb for NH3 would be: Kb = (1.0E-14)/(5.6E-10) = 1.79E-5.
d. To find the % ionization of NH3 in 0.0180 M NH3, you can use the formula: % ionization = ([NH4+]/[NH3]) * 100%. The concentration of NH4+ is equal to the concentration of OH-, which is 5.6E-4 M. So the % ionization would be: % ionization = (5.6E-4/0.0180) * 100% = 3.11%.
e. a. Yes, you are correct. The volume of 0.0120 M HCl needed to reach the equivalence point would be 30.0 mL.
b. To find the pH of the total solution after 15.0 mL of 0.0120 M HCl was added, you can use the Henderson-Hasselbach equation again. The total volume of the solution would be 35.0 mL (20.0 mL NH3 + 15.0 mL HCl). So the pH would be: pH = pKa + log(0.0180/0.0180 + 0.015) = 9.25.
c. To find the pH of the total solution after 40.0 mL of 0.0120 M HCl was added, you would follow the same process as in part b, but now the total volume of the solution would be 60.0 mL. So the pH would be: pH = pKa + log(0.0180/0.0180 + 0.040)
Related to How Do You Solve This NH3 and H2O Chemical Equilibrium Problem?
1. What is the definition of a simple chemistry problem?
A simple chemistry problem is a question or scenario that involves basic chemical concepts and can be solved using fundamental principles and equations.
2. How can I approach solving a simple chemistry problem?
The best way to approach solving a simple chemistry problem is to carefully read and understand the question, identify the relevant information, and utilize appropriate formulas and techniques to solve the problem step by step.
3. What are some common mistakes to avoid when solving a simple chemistry problem?
Some common mistakes to avoid when solving a simple chemistry problem include using incorrect formulas, misinterpreting units, and miscalculating values. It is important to double-check your work and make sure all steps are accurate.
4. What resources can I use to help me solve a simple chemistry problem?
There are many resources available to help you solve a simple chemistry problem, such as textbooks, online tutorials, and practice problems. You can also seek help from a tutor or ask your teacher for clarification.
5. How can I improve my problem-solving skills in chemistry?
The best way to improve your problem-solving skills in chemistry is to practice regularly and familiarize yourself with common chemical concepts and equations. It is also helpful to seek help and guidance from experienced chemists and teachers.
12K
