- 102
Quick question, if i had a circuit of 5 light bulbs whereby 4 were running parellel in a sequence and one was running seperatly, would one be brighter than the others?
sorry if it is hard to visulise :)
Even if you knew the value of the resistance, you will need to know much more to actually calculate a value for luminous flux or intensity. Comparison is the only sensible thing that I can see being done given only these pieces of information.No need to know the value of resistance, because you have to find which bulb is brighter and not how much right?
That is only true if the bulbs are identical. As I said the brightness is directly proportional to the power dissipated by the resistor inside the bulb. That's not a function of only the voltage across it. If you aren't convinced, you can easily try this by using two different light bulbs and a 9V battery.By simple common sense we know that the bulb with more voltage across it glows brighter. So you may check across which bulb more voltage drop will occur.
Which one are you referring to as bulb p?so am i right in believing it to be bulb p? the one on its own but in parallel with the others
