Simple factoring question here: Thanks
  • Thread starter Thread starter nukeman
    Factoring Thanks
The discussion revolves around factoring the quadratic expression 2x^2 - 7x - 2. Participants initially struggle with finding the correct factors and realize that the expression does not factor neatly into integers. The correct factorization is identified as (2x + 1)(x - 4), but confusion arises over a potential typo in the original problem statement. A method involving multiplying the leading coefficient by the constant term is suggested to simplify the factoring process. The conversation highlights the importance of understanding the relationship between coefficients and factors in quadratic equations.
nukeman
Ok, just doing a re-fresher here!
2x^2 - 7x - 2
Factor it...
First, let me ask you guys, when you see this, what is the FIRST thing you think of doing?
For me... And I do not think this is correct.
I would first automatically put the following:
(2x ) (x )
Then, all I need to do is put in the values that add to -4?
nukeman said:
2x^2 - 7x - 2
Factor it...
I take a look at the variable and I check where it is around.
So, here I go for:
x(2x-7)-2
Ok thanks for the input.
The answer from my text says:
(2x + 1) (x - 4)
2x^2 - 7x - 2
Factor it...
(2x ) (x )
So far, so good.
Next, you want to find two factors of -2 so that the x terms add up to -7.
Here are the possibilities:
(2x - 2) (x + 1) -- x term is -2x + 2x = 0x
(2x + 2) (x - 1) -- x term is 2x - 2x = 0x
(2x + 1) (x - 2) -- x term is x - 4x = -3x
(2x - 1) (x + 2) -- x term is -x + 4x = 3x
So, no good, since none of the combinations gave us an x term with a coefficient of -7.
Your quadratic trinomial doesn't factor into "nice" factors (i.e., factors with integer coefficients).
So, here I go for:
x(2x-7)-2
This is not what it means to factor a trinomial.
(2x + 1) (x - 4)
There's a mistake somewhere. If you expand this product, you get 2x2 - 7x - 4. In post 1 you wrote 2x2 - 7x - 2. Did you make a mistake or is it a typo in your book?
Ohh CRAP! Sorry, dam!
Its: 2x^2 - 7x - 4
:redface:
Linguistic problems...
Sorry for the epic fail.
Btw, having now an idea about the problem, I go for the solution of the corresponding equation and then I follow this principle:
ax^2 + bx + c = a(x-u)(x-v)
where u and v are the solutions of the equation.
In this case we indeed have
2(x-4)(x+ \frac{1}{2})
which is equal to the result posted by OP with some manipulation.
Don't quite understand the steps here :(
2x^2 - 7x - 4
So, like I said, I automatically put:
(2x ) (x )
Then, I need to find 2 factors of -4 that add up to -7 ?
No, you need to find two factors of -4 so that the two cross terms (the terms in x) have a coefficient of -7.
You're probably thinking of a method where you multiple a times c (the coefficient of the x^2 term times the constant. Then you factor that number into factors that add up to b.
In your problem, a = 2, b = -7, and c = -4
a * c = -8
We look for factors of -8 that add to -7, and these would be 1 and -8.
Now, write the trinomial using these numbers.
2x2 + x - 8x - 4
Now form two groups:
(2x2 + x) + (-8x - 4)
Factor each group:
x(2x + 1) - 4(2x + 1)
Now, use the distributive property to write as (x - 4)(2x + 1).
2x^2 - 7x - 4
(2x ) (x )
nukeman,
Here's a little trick that I actually picked up from some of my students:
Multiply by 2 to make the leading term a perfect square. (In the en you must divide the result by 2, but that will work fine, because both terms in one of the factors will be multiples of 2.)
\displaystyle 2x^2 - 7x - 4
<br /> \displaystyle =\frac{4x^2 - 7(2x)-8}{2}
\displaystyle =\frac{(2x)^2 - 7(2x)-8}{2}​
Now threat the 2x like it is some other variable such as u.
u2 - 7u - 8 = (u -  ?  )(u +  ?  )
Of course those should be filled in with 8 and 1 .
u2 - 7u - 8 = (u - 8)(u + 1)
Then back to the original:
<br /> \displaystyle =\frac{(2x)^2 - 7(2x)-8}{2}
\displaystyle =\frac{(2x-8)(2x+1)}{2}
\displaystyle =\frac{2(x-4)(2x+1)}{2}​
Giving you the desired result.
Fantastic! Thank you Mark! :)
Sammy, pretty cool way of doing, never seen that!
a * c = -8
2x2 + x - 8x - 4
Factor each group:
Learn the cross method, it'll save you a heap of heartache. I still remember it even after years of not using it (don't be discouraged by that, it's just because most the quadratics I see can't be factorized with integer coefficients).
http://www.youtube.com/watch?v=2dqAPKgC-KI
