Simple Harmonic Motion and equilibrium
The discussion revolves around calculating the speed of a 100-g block in simple harmonic motion when displaced from its equilibrium position. The block is initially 0.20 m below equilibrium and moving upward at 2.10 m/s, with a spring constant of 5.2 N/m. The correct speed at a displacement of 0.324 m is identified as 1.02 m/s, but the user struggles to derive this value using their calculations. Key equations of motion are discussed, including the relationship between angular frequency, amplitude, and displacement. Ultimately, the user realizes the need to correctly apply the formula for velocity in simple harmonic motion, which involves using the amplitude and displacement.
Patdon10
A 100-g block hangs from a spring with k = 5.2 N/m. At t = 0 s, the block is .20 m below the equilibrium position and moving upward with a speed of 2.10 m/s. What is the block's speed when the displacement from equilibrium is .324 m?
w0=sqrt(k/m)
x(t) = Bsin(w0*t) + Ccos(w0*t)
v(t) = w0Bcos(w0*t)-w0Csin(w0*t)
I know the answer is 1.02 m/s, and I'm not getting that at all : /
w0=sqrt(k/m)
= sqroot (5.2/.100) = 7.2111 rad/s
x(t) = Bsin(0) + Ccos(0)
x(t) = B
v(t) = w0Bcos(0) - w0sin(0)
v(t) = w0B
1.9 = 7.2111B ---> B = 0.26348
0.297 = 0.26348*sin(7.2111*t) + (0.2)cos(7.2111*t)
0.297 = 0.03307344t + 0.19841808t
0.297 = 0.2314915203t
t = 1.28298436
v(t) = [(7.2111)(0.26348)cos(7.2111*1.28298436)] -
[(7.2111)(0.2)sin(7.2111*1.28298436)]
v(t) = 2.418364634 - 0.2318690865
v(t) = 2.31869 m/s
Can anyone see what I'm doing wrong? Thanks in advance!
In the simple harmonic motion the velocity is given by
v = \omega\sqrt{(a^2 - x^2)}
You have found ω. From the given data, you can find the amplitude a. In the second case using a and x, find v.
Is the amplitude simply:
x = Asin(w_0*t)
I don't think that equation would work, because I don't have a time in the given. Or would the amplitude simply be what B is, because it matches the amplitude equation.
edit:
of course that wouldn't make sense either because that would make V a non-real answer.
2.1 = 7.2111(a^2 - 0.2^2)^1/2
Solving this you get
a^2 = 0.1248. Next
v = 7.2111(0.1248 - 0.324^2)1/2
Solve this to find v.
Thanks for the response!
ok, I see now. I should have been able to figure that out from the givens. I didn't understand why you didn't have a squared on the amplitude in the equation, but I see you already added it. Why would my method not work? What am I doing wrong?
simple harmonic motion is expressed as
y = Asin(ωt) or x = Acos(ωt)
The velocity at any instant is given by
v = dy/dt = Aωcos(ωt) = ω(A^2 - y^2)^1/2
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
