Simple Harmonic Motion: Mass on a Spring Homework Solution
The discussion focuses on demonstrating that a mass attached to a spring executes simple harmonic motion (SHM) when displaced from its equilibrium position. The net force acting on the mass is derived from the restoring force of the spring and the gravitational force, leading to the equation of motion. The relationship between force and displacement is emphasized, highlighting that the restoring force is proportional to the displacement from equilibrium, which is a key characteristic of SHM. Additionally, the period of oscillation can be expressed in terms of the spring constant and the mass, linking it to gravitational acceleration. Understanding these principles is crucial for solving the homework problem effectively.
bmb2009
A massless spring hangs down from a support, with its lower end at y=0, where the y-axis is vertical and points downward (normal orientation of y). When a small unknown mass is attached to the spring, the lower end of the spring moves down to a position y_0 for the mass being in equilibrium
a.) Demonstrate that when the mass is pulled down to a position of y=y_0 + A and released from rest, it will execute a simple harmonic motion around y_0
b.) Express the period of oscillations of the mass in terms of y_0 and g.
Not really sure what/how to demonstrate that it executes s.h.m. I set up a force equation such that F_net= F_restoring - mg
F_net= -k(y-y_0) - mg
let Y be acceleration
mY= -k(y-y_0) - mg
mY=-kA-mg definfe ω^2 = k/m
Y=-(ω^2)A - g is the final equation i got... not sure how this proves anything and not really sure what to do.. any help? thanks
Start with the definition of SHM.
Good start - how is the force related to displacement? Use words - and relate it to the definition of SHM.
