Simple Pendulum & Elevator Homework | Period Formula for Accelerating Elevator
The discussion revolves around determining the period of a simple pendulum suspended in an upward-accelerating elevator. The key formulas presented include T = 2π*(L/(g+a))^(1/2) and T = 2π*(L/g)^(1/2), with the consensus leaning towards the former as it accounts for both gravitational acceleration (g) and the elevator's acceleration (a). Participants express confusion about the problem's mathematical aspects and the relevance of free body diagrams. The conversation also references Einstein's equivalence principle, highlighting the relationship between gravitational fields and acceleration. Ultimately, the focus is on correctly applying the formulas to find the pendulum's period in the context of the elevator's motion.
hansel13
A simple Pendulum is suspended from the ceiling of an elevator. The elevator is accelerating upwards with acceleration a. The period of this pendulum, in terms of its length L, g, and a is:
2\pi*(L/a)^(1/2)
OR
2\pi*(L/(g+a))^(1/2)
OR
2\pi*(L/g)^(1/2)
T = 2\pi*(L/g)^(1/2)
Not sure where to start. It doesn't seem like there's really math involved here. I tried drawing a free body diagram, but that made things worse. I'm pretty sure it's the middle one, because the other 2 just don't make sense, because the formula needs to both a and g into account, right?
Right.
"we [...] assume the complete physical equivalence of a gravitational field and a corresponding acceleration of the reference system." (Einstein 1907)
OK thanks
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
