Solving for the Third Force in a Simple Physics Problem with Constant Velocity
  • Thread starter Thread starter Rasine
    Physics
To find the third force acting on a particle moving with constant velocity, the net force must equal zero. The components of the third force, F3, can be determined by setting up equations based on the known forces F1 and F2. Specifically, the equations f1x + f2x + f3x = 0, f1y + f2y + f3y = 0, and f1z + f2z + f3z = 0 should be used to solve for the components of F3. This approach ensures that the sum of the forces in each direction balances out to maintain constant velocity. The magnitude of F3 can then be calculated after finding its components.
Rasine
Three forces act on a particle that moves with a constant velocity v = (2 m/s) x - (7 m/s) y. Two of the forces acting on this particle are F1 = (-9 N) x + (10 N) y + (2 N) z and F2 = (6 N) x + (1 N) y + (9 N) z. What is the magnitude of the third force?
so what i was trying to do is take the f1z component and the f2z compoment and finnding the magnitude by doing squroot(9^2+2^2)...but that is not how you do it...
can someone please point me in the right direction?
First find the components of the third force, considering that the net force on the particle must be zero.
so if the net force does not change the velocity then f1 and f2 should yeild 0 right?
No. You need to find the components of the third force; F3. Since the acceleration is zero in each direction, you know that the sum of the components of the forces in each direction must be zero; i.e. f1x+f2x+f3x=0... etc.
so how would i go about doing this... f1 and f2 should be equal right? um...so the magnitude of f3 should make be the variable that makes f1 and f2 =0 right?
Don't think about the magnitude yet. f1 and f2 are not equal; you are given the values of them. Set up three equations, f1x+f2x+f3x=0, and the other similar two. Then you know the values for f1x and f2x, and so obtain -9+6+f3x=0. This will give you the x component of f3. Use similar equations for the y and z components.
