triden
- 174
Hey guys,
Right now I have a circuit designed and seems to work fairly well. Now the output from my circuit is a negative output and I need it to drive a relay. The relay I am using says it draws about 100mA and my chip will output 50mA max. I figured I would put a transistor on the output to drive my relay...the only problem is that the output is negative. In this case I am not sure what to do. Do I need an PNP instead of an NPN?
So far I figure the IC neg output goes to base, emitter to ground side of coil and collector to ground rail of circuit...but I don't think this will trigger because the base is negative.
Thanks for your suggestions
