Is it possible to simplify the drag equation for 3D programming purposes?
  • Thread starter Thread starter Gibbon
    Drag
Calculating drag in 3D programming involves understanding air density, object area, and drag coefficients, which can complicate implementation. However, engines like Unity3D simplify this by allowing users to set drag and angular drag properties without detailed inputs. This is achieved by using predefined drag coefficients that can be adjusted through trial and error rather than precise calculations. Many programmers prioritize creating an enjoyable gaming experience over achieving realistic physics simulations. Simplifying the drag equation can enhance efficiency in game development while still providing satisfactory results.
Gibbon
Simplified drag equation??
Hi, I am a 3D programmer and I am trying to apply drag to some of my objects in my software.
After looking around and from previous research i know that calculating drag isn't such a simple thing to do and involves knowing air density, object area and the drag coefficient.
But, whilst research on the net i realized a well used 3D engine "unity3D" allows you to add a ridig body into the scene, give it some mass and then "simply" set its drag and angular drag properties without any inputs of air density, area or any coefficients?
So how could this be done?
Thanks
Andy
You just do it.
The drag coefficients are just numbers.
You can calculate the correct numbers from all the data you mentioned, or you can guess a figure, try it out, adjust it, and so on ... trial and error.
Most programmers are not as interested in making a realistic point-for-point physical simulation as they are in making a fun experience for the gamer.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
