Simplifying the Equation for Beginners
  • Thread starter Thread starter LENIN
    Simplify
The discussion focuses on simplifying a complex equation involving physical parameters for a project. The original equation is analyzed to identify key components, with approximations made for variables such as mass (M, m), length (l), and radius (r). It is noted that for small values of r, certain terms can be simplified significantly, leading to a more manageable form of the equation. The participant seeks guidance on which parts of the equation are critical for simplification, ultimately aiming for a clearer understanding of the relationship between the variables. This simplification process is essential for effectively applying the equation in the project context.
LENIN
I have to find out how to make this simplification
2\pi \sqrt{ \frac {Ml^2+2Mr^2/5+m(l-r)^2/3} {(Ml+m(l-r)/2)g}} \approx 2\pi \sqrt{\frac{l}{g}(1+\frac{2r}{5l}-\frac{1m}{6M})}.
This is for a project I have to do, but I have never done any such simplifications before. I don't know which parts of the equation are important and which aren't. If it helps this are the values of the variables:
M\approx10kg
m\approx20g
l=227cm
r=6cm
(Ml+m(l-r)/2)g would simplify to ~Mlg, in the denominator under the root.
(l-r)2 would simplify to l2 for very small r, otherwise l2-2rl since r2 would be small.
r/l = 6/227 = 0.026
m/M = 0.02/10 = 0.002 so M-m ~ M is a good approximation.
Thank you.
