Sine wave generator without constant voltage
The discussion highlights issues with a sine wave generator used in a physics lab, where voltage fluctuations with frequency were observed, potentially due to the generator's impedance or the circuit design. The importance of taking comprehensive data is emphasized, suggesting that adjustments and observations should be meticulously recorded for accurate results. Factors like ambient temperature, time of day, and assembly torque can influence experimental outcomes and should not be overlooked. The conversation also critiques a reliance on calibration stickers, advocating for a return to careful measurement practices. Overall, attention to detail in lab work is crucial for reliable results.
fedaykin
In physics lab we were using a signal generator with sine wave to find the frequency of a circuit quite precisely. Unfortunately, we had trouble and when checked with a circuit with purely resistive impedance, voltage changed with the frequency of the sine wave.
The signal generator is rather ancient, but my professor stated it worked the previous semester. Is this often something a simple dusting could fix?
Good perception. Lack of attention in the lab runs rampent in these times, and I'm glad to see someone paying attention.
Chances are you have one or both of the following:
1 - The impedance of your test circuit varies with frequency and interacts with the source. After all, the signal generator has some impedance (typically 50 ohms) and in some cases, poorly designed equipment can interact with reactive loads.
2 - The generator's output naturally varies with frequency. I have an old piece of equipment. I love it dearly, but it has the same problem.
The answer is, and always will be - take more data! Keep a column for your excitation as well as your output. If it's a linear system, you can correct it in math later. Otherwise, you can adjust the source before each reading. But, take the reading anyway and make a note that you had to adjust the output and why.
Keeping track of things that seem unimportant, and teaching your staff to do the same, will likely aid you in your career. In many cases the ambient temperature, time of day, season of the year, applied torque during assembly, etc.. ended up being linked to experiment results.
Temperature is pretty obvious. Time of day tends to be related to what people are doing, how much vibration is present, and what the heating and air conditioning are doing. Season of the year - humidity and heat load. Torque - leaky fittings and poor electrical connections.
At one time, these tenants were held self evident, but now, most companies and labs take for granted that calibration stickers mean that everything in the system is working properly. It was the old school technicians, turned out at such places as GE, that embarassed me a few times and led me to understand the value of careful measurement, recording, and compensation.
I wish you well,
Mike
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
