Single conservative force acting on a particle
The discussion centers on calculating the potential energy function U(x) for a particle under a conservative force represented by F = -Ax + Bx^2. Participants express uncertainty about the limits of integration, specifically where to start the integration to find U. It is clarified that the lower limit should be at a known potential energy point, typically U=0 at x=0, while the upper limit can be defined based on the problem's requirements. A suggestion is made to use a different variable for integration to avoid confusion. The conversation emphasizes the importance of correctly setting integration limits for accurate potential energy calculations.
Robb
U(final)(x)= (-) Integral F dx + U(initial)
Integration from (x-initial to x-final)
U(final)(x)= (-) integral (-Ax+Bx^2)dx
Not sure on limits of integration
You have to start the integration at a place where U is known. What place is that?
If you want to give the value of U at location coordinate x, what is the upper limit of integration?
Not sure. Lower = 0. upper x=2.00 & x=3.00?
I was referring to part (a). There is no 2.00 or 3.00 in part (a). Once you have solved part (a), part (b) is just a question of substitution and subtraction.
I think you may be confusing yourself by mislabelling your integration variables.
That can't be right because the LHS depends on X while the RHS does not. By using x as the integration variable you make it disappear once the integral is taken. Instead use y as your integration variable and x as one of your limits of integration. Which one?
So, my potential energy function is U(x) = (-) integral F dx = (-) integral (-Ax+Bx^2) dx = 1/2Ax^2 + 1/3 BX^3
U=0 @ x=0
Though I am seeing this as a lower limit
