What is the Coordinate of Point B in a Sinusoidal Wave?
  • Thread starter Thread starter jpond89
    Sinusoidal Wave
To find the coordinate of point B in the sinusoidal wave, it is essential to determine the phase difference of 60.0° at a constant time. The wave function is given as y = (15.0 cm) cos(0.157x - 50.3t), where the phase at point A (the origin) is zero. The phase difference of 60° corresponds to a shift of π/3 radians, leading to the equation 0.157x = π/3. Solving for x gives the coordinate of point B as approximately 6.37 cm. This calculation confirms the relationship between phase and position in sinusoidal waves.
jpond89
Consider the sinusoidal wave in the figure, with the wave function below.
At a certain instant, let point A be at the origin and point B be the first point along the x-axis where the wave is 60.0° out of phase with point A. What is the coordinate of point B?
and I am not allowed to post the image but here's some helpful information:
its a cosine graph, and \lambda = 40 cm, T = 0.125 s, f = 8.00 hz, k = 0.157 rads/cm
Some equations that I have are:
k=2\pi/\lambda
v=\lambda*f
y=Asin(kx-\omegat)
What I have tried so far is:
y=15*sin((.157)x-(50.3)t + \pi/3)
The example says " The vertical position of an element of the medium at t = 0 and x = 0 is also 15.0 cm "
The only problem is that I am really stuck and I cannot seem what to set the 60.0\circ equal to. Help would be much appreciated! Thank you!
Everything in the argument of the cosine is the phase of the wave. So the phase is a function of both x and t. However, we're looking at this wave at a particular "instant", which means that t is constant. So, the only thing that would cause a phase change is x. So how far from the origin would the x coordinate of point B have to be in order for 0.157x - 50.3t to differ from 0.157*(0) - 50.3t by 60 degrees, given that t is constant?
Would x = 6.37 * \pi because that would make it (\pi/3 -50.3t)
I think you might be off by a factor of 3. Check your work again.
