How Do You Derive the Equation for a Traveling Sinusoidal Wave?
  • Thread starter Thread starter moonkey
    Sinusoidal Wave
The discussion focuses on deriving the equation for a traveling sinusoidal wave based on given parameters, including frequency, velocity, and specific displacement and velocity at a point on the string. The derived wave equation is presented as y=-0.02258Sin(314.16t-13.09x-1.343), which is confirmed to be equivalent to the book's answer with a different arrangement. The second part of the problem involves calculating the minimum distance to a point with a specified acceleration, initially leading to confusion in differentiation. Ultimately, the user resolves the issue with their calculations. The thread emphasizes the importance of correct differentiation in solving wave equations.
moonkey
A sinusoidal wave of frequency 50Hz travels along a string at a velocity of 24m/s. At a given instant the displacement and velocity of a certain point in the string are 22mm and 1.6m/s respectively.
Taking the certain point and given instant to be x=0, t=0 derive the traveling wave equation which gives the displacement of any point on the string as a function of position x and time t.
A point in the string has an acceleration of 2000m/s², 3ms before the instant specified above. What is the minimum distance possible between this point and the point x=0?
From the information given what I know is
f=50Hz, v=24m/s, λ=0.48m, ω=314.16/s, k=13.09/m
Equation for sinusoidal wave:
y(x,t)=ASin(ωt-kx+φ)
I managed to derive the traveling wave equation as
where A=-0.02258, φ=-1.343
The answer in the back of the book is
y=-0.02258Sin(13.09x-314.16t-1.343)
Am I right in thinking that both those equations are the same thing?The biggest problem I'm having is the second part of the question.
Here's what I've done (the answer in the back of the book is -55mm)
y=ASin(ωt-kx+φ)
dy/dx=-ωACos(ωt-kx+φ)
d²y/dy²=-ω²ASin(ωt-kx+φ),
where d²y/dy²=acceleration = 2000m/s² and t=3ms=0.003s
so subbing in my knowns and rearranging I get:
arcSin[2000/(-(314.16²)*(-0.02258)) - 314.16*(-0.003) + 1.343]/-13.09 = x
x=-0.2597Help please
Never mind. Figured it out. My differentiation was wrong
