What is the tension force of the rope in this physics problem?
  • Thread starter Thread starter F|reWa||
    Physics
To solve the first problem involving a 100-pound weight on a 30-degree ramp with a coefficient of friction of 0.35, it's essential to break down the gravitational force into components: one parallel to the ramp and one perpendicular. The friction force, derived from the perpendicular component, must be subtracted from the parallel component of the weight to determine the tension in the rope. For the second problem regarding a jet plane climbing at a constant airspeed, a triangle can be drawn to visualize the situation. The tangent of the climb angle can be calculated using the altitude and horizontal distance. It's advised to use exact trigonometric values for calculations and round them later for accuracy. Additionally, the coefficient of friction in the first problem indicates limiting static friction, which should be considered when applying the formula for friction force.
F|reWa||
I am totally stuck on these two and I would like to know how to do this problem:
1. A 100 pound weight is resting on a 30 degree ramp with a coefficient of friction µ = 0.35 and is restrained by a rope. What is the tension force of the rope?
Sin 30 degrees = 0.5
Cos 30 degrees = 0.866
Tan 30 degrees = 0.577
2. A jet plane is climbing at a constant airspeed in no-wind conditions. The plane takes off from sea level. The plane is directly over a point on the ground that is 4 statute miles (21,120 ft) from the takeoff point and the altimeter reads 15,840 ft. Find the tangent of the climb angle and the distance that it has flown through the air.
-AML
For problem 1, break the gravitational force into two components - one parallel to the plane and one perpendecular. Friction force is calculated from the perpendicular component. Subtract the friction force from the parallel component of the weight.
For problem 2, draw a triangle and solve it.
Also, it's generally better in such problems to use the exact values if possible, and round up later. eg. sin 30 = 0.5 , cos 30 = 0.5 * [squ]3, tan 30 = 1/([squ]3)
However, the question as you gave it is not entirely correct. The coefficient of friction gives the limiting static friction of the two surfaces. You cannot use F = [mu] R unless you assume friction is at limiting. But that's a minor point. It probably doesn't matter.
