Ski Jumper's Initial Velocity - Solve the Problem
To determine the ski jumper's initial velocity, the problem requires resolving the final velocity into its horizontal and vertical components. The jumper lands 51.0 m horizontally with a final velocity of 23.0 m/s at an angle of 43.0 degrees below the horizontal. By applying kinematic equations and considering the effects of gravity, the initial velocity can be calculated. The discussion emphasizes the importance of understanding the relationship between the components of velocity and the influence of gravitational acceleration. Ultimately, the solution involves using the given data to backtrack to the initial conditions of the jump.
ayerski
After :Leaving the end of a ski ramp, a ski jumper lands downhill at a point that is displaced 51.0 m horixontally from the end of the ramp. His velocity, just before lenading, is 23.0m/s and points in a direction 43.0 degress below the horizontal. Neglecting air resistance and lift he experiences while airborne, find his initial velocity (magnitude and direction) when he left the end of the ramp. Express the direction as an angle relative to the horizontal.
x = 1/2at(squared) +vot +xo
Thinking I should use the final velocity and figure out how much the acceleration of gravity has effected it, just need some guidance there.
Yeap you are correct you just have to resolve the velocity into the x and y component.
