Skiing: Calculating Speed and Friction Coefficient
  • Thread starter Thread starter st3dent
    Slope
A skier descends from a peak of 850m to a lower peak of 750m over a distance of 3.2km with an average slope of 30 degrees. The calculated speed upon reaching the lower peak, without using poles, is 44.27 m/s. To determine the maximum tolerable coefficient of friction that allows the skier to just reach the lower peak with zero velocity, calculations show that the coefficient of friction is approximately 0.036. This value is derived from the work-energy principle, considering the energy lost due to friction over the distance traveled. The discussion confirms the accuracy of the calculations and the final result for the friction coefficient.
st3dent
2. Two mountains are at elevations of 850m and 750m above the valley between them. A ski run extends from the top of the higher peak to the top of the lower one, with a total length of 3.2km and an average slope of 30 degrees,
a) A skier starts from rest on the higher peak. At what speed will be arrive at the top of the lower peak if he just coasts without using poles?
b)How large a coefficient of friction would be tolerable without preventing him from reaching the lower peak?
what I've done:
2a) (m)(9.8)(850) = (m)(9.8)(750) + (0.5)(m)(vf^2)
vf^2 = 1960
vf = 44.27 m/s
b)I am stuck on this one.
Thanks in advance for your help.
Assume that the skier just arrives at the second peak with 0 velocity. How much energy must he/she have lost? Okay, now use "energy = force*distance" to calculate the friction force necessary to account for that energy loss.
(a) looks right, I didn't check your calculation but the formula is correct.
As for (b), let's write down the work-energy equation:
W_{friction} = \Delta E_m = \Delta E_p + \Delta E_k
Our worst case scenario would be if the coefficient of friction would be so large, that the skier would reach the lower peak just barely - without any speed. In that case his kinetic energy would be 0 at first (since he starts from rest) and 0 at the end (since he has no speed when he reaches the peak):
W_f = (mgh_2 - mgh_1) + (0 - 0) = mg(750m - 850m) = -100mg
Now what is the work of friction? It is the force of friction times the distance, which is 3.2km or 3,200 meters. Don't forget the work is negative, though, because the force vector is directly opposite to the distance vector all the time:
-xf_k = -3200f_k = -100mg
f_k = N\mu _k = \frac{100mg}{3200} = \frac{mg}{32}
\mu _k = \frac{mg}{32N}
Now all you have to do is find the normal force, N...
I understand the following:
Since the change in kinetic energy is zero,
Ei = Ef
mgh1 = mgh2 + Ffrd
mgh1 - mgh2 = Ffrd
mg(750 - 850) = Ffrd
Since Ffrd = \mu _kFnd
Fnd = mg(750 - 850)
Fn = -100mg / d
Fn = -100mg/-3200
Fn = mg/32
AS;
Ek = 0.5mv2
In part a), i found the speed of the skier at the top of the second slope to be 44.27 m/s.
Then,
(m)(9.8)(850) = (m)(9.8)(750) + (0.5)(m)(v2)
(m)(9.8)(850) = (m)(9.8)(750) + (0.5)(m)(44.272)
However, i can't solve for m, since it cancels out.
I do know that the force down the slop is mgsin30 and that
Fn, the normal force, is mgcos30. But how can i use this to solve this problem?
I THINK I have a solution now.
Since Ffrd = mg / 32
and Ffr = \mu _kmgcos30
then \mu _kmgcos30 = mg/32
\mu _k = mg/32mgcos30
\mu _k = 1/32cos30
\mu _k = 0.036
Is that the right answer...THANKS!
Yes, 0.036.
