Small hole at bottom of cylindrical tank draining water?
khfrekek92
the tank has a radius of 2m, containing an initial water level of 3m. A hole at the very bottom (underneath) of the tank has radius .005m. How long will it take to empty the tank?
Bernoulli's principle.
A=radius at top of tank
a=radius of drain hole
after solving V=sqrt(2gh) [at the hole in the bottom], i set dV/dt=--a*sqrt(2gh), so A(dy/dt)=-a*sqrt(2gh). After integrating both sides and solving for C, I got that (A/g)sqrt(2gh)=-8at+(A/g)sqrt(6g)
Then I plugged everything in with h=0 and got that t=15649.2sec=4.35 hours.
Did I do this right? Did you get the same answer?
Thanks so much in advance! I appreciate it!
Hey You can't apply sqrt(2gh) when area of hole is given.sqrt(2gh) is when area of hole is very small.You need to apply continuity equation to get velocity outside hole Av1=av2, where v1 is velocity just before water is inside cylinder, & v2 is velocity of water just after coming out of hole.
you should get velocity v2=sqrt(2gh/(1-(a2/A2))).
Even accepting the point from 1994Bhaskar, since the radius of the hole is given as 0.005 m and the radius of the tank is 2 m, I think a simple calculation shows the area of the hole is in fact "very small" in relation to the cross sectional area of the tank. The correction factor for v2 is 0.99999375, using the information given. In other words, v = sqrt (2gh).
Yes that is a great point 1994Bhaskar, but my professor said we are allowed to assume that the velocity at the top is negligible compared to the bottom, So I'll just use v=sqrt(2gh). Thanks so much for your help guys! :)
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
