Small sphere rolling off the top of a large sphere
  • Thread starter Thread starter myko
    Rolling Sphere
A small uniform solid sphere rolls down a larger fixed sphere after a slight disturbance, and the discussion focuses on determining the height at which the small sphere loses contact with the larger one. The initial attempts involve applying Newton's second law and conservation of energy, but there is confusion regarding the inclusion of rotational kinetic energy in the calculations. Key equations discussed include the relationship between speed, gravitational potential energy, and the moment of inertia of the small sphere. Participants suggest expressing the angle of separation and height in terms of known variables to simplify the problem. The conversation highlights the importance of correctly accounting for rotational dynamics in the energy conservation equation.
myko
[>A heavy sphere of radius r = 1.00 meter is fixed with respect to the ground. A small uniform solid sphere is placed at the top of the larger sphere. After a slight disturbance, the smaller sphere begins to roll downward without slipping. How high h is the small sphere above the ground at the instant it loses contact with the large sphere
My atempt of solution:
I think, that at the moment when it loses contact, speed of the small sphere is higher than the one in $\Sigma F=mg\cos\theta=mv^2/r$. $\theta r$ is an arc traveled on the sphere. Also since it falls without slipping, $v=\omega r$, where $\omega$ is the angular velocity of the small sphere. The speed at a height h can be found from $$mg(2r)=1/2mv^2+mgh.$$
From foce equation I would get $$v=\sqrt{rg\cos\theta}$$
And from energy conservation:
$$h=\frac{4g-v^2}{2g}$$
substituting the expretion for velocity
$$h=\frac{4-r\cos\theta}{2}$$
I am not sure if this is correct or no. And I can't express $\theta$ in some other way. Could anyone help?
Have you forgotten about rotational kinetic energy? The small sphere rotates; this will consume energy. Your conservation of energy equation will be slightly different.
$$mg(2r)=1/2mv^2+1/2I\omega^2+mgh$$$$h=\frac{2rg-7/10v^2}{g}$$
also $$h=1+cos\theta$
and now I would substitute v. Is that right?
and now?
Let ##m## and ##r## be the mass and radius of the small sphere. You need to express ##I## and ##\omega## in terms of ##m##, ##r## and ##v##.
Also, working with ##h## is more complicated; find ##\theta##, the angle at the center of the large sphere such that the spheres just begin to separate, then convert that to a height.
Ok, ty. I got it.
Hi
I'm working in the same problem and tnx i got it
