So if a microprocessor contains trillions of transistors
  • Thread starter Thread starter jaydnul
    Transistors
Microprocessors contain a vast number of transistors, but not every transistor connects directly to many others; the design prioritizes efficiency and functionality. Circuits are etched onto silicon chips, a fabrication technique that does not alter the underlying logic of the circuit. Logic gates, such as AND and OR, are constructed from these transistors and serve as the fundamental building blocks of microprocessors. These gates are organized into more complex structures like registers and ALUs, ultimately forming the complete microprocessor architecture. The distinction between signals from adjacent transistors is managed through the design of these logic gates and their arrangement.
jaydnul
does that mean there are trillions of connections to each transistor that connect to various other parts of the board? how does that work? how is the signal from one transistor distinguished from another transistor right next to it on the microprocessor?
First, "trillions" is just silly.
Second, why would anyone WANT to have a transister connecting directly to more than a small number of others?
Circuits are etched on silicon chips and theoretically, one could build exactly the same thing with discrete transistors (in cans) and wires.
EDIT: my point is that etching circuits is just a fabrication technique. There's nothing different about the LOGIC of the circuit due to the fabrication technique.
Look up how the different logic gates (AND, OR, NAND, NOR and so on) are built. These are the building blocks you put together in order to create a microprocessor, and they are built from transistors.
The gates are then combined into combinational and sequential logic (clocked) logic. Which in turn is combined into registers, ALU's, caches, instruction set decoders and so on. Which in turn are assembled into a microprocessor or other logical hardware.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
