Soccer goal. Need help defining height of ball at a distance.
  • Thread starter Thread starter lorenzosounds
    Ball Height
The discussion revolves around determining whether a kicked soccer ball crosses a goal, given its initial distance, angle, and speed. The net height is specified, and gravity is considered in the calculations.
  • Participants explore the use of trigonometric functions and kinematic equations to define the ball's height at a specific distance. There is consideration of how to calculate the height at any moment during the ball's flight and the implications of the ball hitting the ground before reaching the goal.
Some participants have provided relevant equations and suggested looking into kinematic equations for vertical motion. There is ongoing exploration of the definitions and implications of the variables involved, with no explicit consensus reached yet.
Participants question the meaning of certain variables in the equations presented, and there is a mention of the need for clarity on the behavior of the ball if it does not reach the goal.
lorenzosounds
Write a program to determine whether or not a ball kicked is a goal. Initial distance (from goal), initial angle, and initial speed are user-defined variables. The net is 2.54 m high. Gravity is 9.81m/s^2
flightTime=(2)initSpeed*sin(initAngle)/gravity
range=flightTime*initSpeed * cos(initAngle)
Trying to define whether or not the ball is above the net when the ball is at the initial distance. I've been thinking about it in terms of trig functions, specifically Sin. Also, maybe using the pythagorean theorem (initDistance^2 + height of ball^2 = Length of tangent line between initDistance and ball^2).
I'm also aware of the kinematic equation vi^2 * (sinθi)^2/2g, which gives the max height of a parabolic flight. However, this doesn't let me define the height at any moment.
I found this formula defining height.
y(t) = (Vo sinm)) - (gt²)/2
What does the A-hat represent?
Welcome to Physics Forums.
"Relevant equations" should probably include all kinematic equations, applied to both horizontal and vertical motion.
You can use the kinematic equation that tells you the ball's height at any given time, given the acceleration and initial velocity.
Also, what is supposed to happen to the ball if it hits the ground before reaching the goal? Does it come to a complete stop, bounce off the ground, continue rolling along the ground, or something else?
That looks similar to the following equation (2nd equation listed under "Displacement"):
http://en.wikipedia.org/wiki/Projectile_motion#Displacement
But there is no A-hat in that equation.
I'll suggest that you look at a physics textbook, in the section that discusses projectile motion, which will have all the equations and also explain what all the terms mean.
  • · Replies 22 ·
