- 7,864
- 1,602
- TL;DR Summary
- When a heavy brass fitting is soldered to copper pipe, how can I be sure the brass is hot enough? Does the visual appearance of flux indicate when a joint is hot enough to apply solder?
When soldering a brass fitting (e.g. https://www.pexuniverse.com/1-pex-x-3-4-pex-brass-pex-copper-fitting-adapter-lead-free-brass ) to copper (e.g. a 3/4 inch copper coupling) I think there is a danger that copper gets hot enough to melt the solder, but the brass fitting (being more massive) isn't hot enough. Can I use the visual appearance of flux (e.g. Oatey H-20@5) on the brass as a clue? Should the flux liquify or bubble? Should I apply the torch mainly to the brass instead of at the middle of the joint?
Another question, on the above example is whether the raised lip on the brass fitting should be set snug against the end of the coupling - or should I leave a small gap for the solder to flow into.
I ask the general question, because I soldered the particular example and even though the solder flowed around the joint, the joint leaked.
