jromega3
- 27
You want to construct a solenoid 20cm long that has an interior magnetic field Strength B (Bc) of about 1.5MN/C. The coil has to be wound as a single layer of wire around a form whose diameter is 3.0 cm. You have two spools of wire handy. #18 wire has a diameter of about 1.02mm and can carry a current of 6.0A before overheating. #26 wire has a diameter of 0.41mm and can carry up to 1.0A. Which kind of wire should you use and why? What potential difference do you want to put across the coil's end?
B=NI/(cLE0)...or simplified as about 377NI/L.
377NI/L must equal about 1.5X10^6N/C...so NI/L must equal 3979. I Have an I...and don't really know where to go from here...and not even sure if this is the right path to take. Not really understanding the question? So I unwind the wires and see how many of them I'd need to fill the 3cm diameter? Any help would be appreciated.
