Solve a Strange Trig Problem: Distance to a Castle Spotted by Two Men in a Car
  • Thread starter Thread starter danne89
    Strange Trig
The discussion revolves around a trigonometry problem involving two men in a car observing a castle at different angles. Initially, the car travels at 90 km/h, with the first observation at a 30-degree angle, leading to a calculated distance of approximately 30 km. After 15 minutes, the second man observes the castle at a 40-degree angle, resulting in a distance of about 19 km. Participants note that the distances derived from the two angles contradict each other, indicating a potential error in the problem's setup. The conclusion emphasizes the need for clarity in the problem's parameters to resolve the contradictions.
danne89
A car travels with a velocity of 90 km/h on a stright line. And a man in the car saw a castle left of the road. The angle the straight line to the castle from the cars position was 30 degrees. 15 min (same vel) later another man spots the castle in an 40-degrees angle. After another 15 min they spot a perpendicular way towards the castle. How long is this way into the castle?
tan 30 degrees = x/45 => x=~ 30 km
tan 40 degrees = x/22.5 => x~= 19 km
Have you tried to draw the problem to help you understand better? What progress have you made?
I'm sorry. I was in a hurry when I tried to descibe my progress. I indeed draw a picture and obtained those equations above. My point is that they contridict each other.
And this other man, where is he located?
In the car he also.
So you have two right triangles with a common side, the road to the castle. One has an angle of 30 degrees and a side of 45 km. The other triangle has a angle of 40 degrees and a side of 22.5 km,
You are right. The information given is contradictory.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
