Solve acos²θ+bsinθ+c=0 for all values 0≤θ≤360°
In summary: Do not take my word for it: test it for yourself. Take your value ##\theta = 40.54^o## and plug it into the function ##f(\theta) = 16 \cos^2(\theta) + 6 \sin(\theta) -12##, to see if you get zero (except for small roundoff errors).
DanRow93
25
a=16
b=6
c=-12
So 16cos²θ+6sinθ-12=0
Cos²x=1-Sin²x
Identity: Cos²x=1-Sin²x
16(1-Sin²θ)+6Sinθ-12=0
16-16Sin²θ+6Sinθ-12=0
6Sinθ-16Sin²θ=12-16=-4
Divide by 2(?)
3Sinθ-8Sin²θ=-2
3Sinθ-4Sin³θ=-2
3Sinθ-4Sin³θ=Sin3θ
Sin3θ=-2
I realized that I am stuck at this point and can’t work out how to find θ from this, although it feels like I am missing something obvious. Any help would be appreciated!
DanRow93 said:
3Sinθ-8Sin²θ=-2
3Sinθ-4Sin³θ=-2
3\sinθ-8\sin^2θ=-2$$
$$3\sinθ-4\sin^{\color{red}{3}}θ=-2
Where does that three come from ?
I tried to change 8Sin²θ into Sin³θ, but I guess that doesn’t work. I think it’s because I had Sin3θ written down, so I was trying to make it work out as that.
16Sin²θ-6Sinθ=4
Sinθ(16Sinθ-6)=4
I still can’t work out what to do next.
Hint: Let sinθ = x. What kind of equation would you have for x?
A quadratic equation?
ax²+bx+c=0
16x²-6x-4=0
Sinθ=6±√-6²-(4×16×-4)∕2×16 (Sorry not sure how to type that so it looks more clear)
Sinθ=0.65
Sinθ=-0.28
Sin–1(0.65)=40.54°
Sin–1(-0.28)=-16.26°
But seeing as it is between 0° and 360°
θ1 = 40.54°
θ2 = 180°-40.54°=139.46° (?)
Hopefully that's right
ax²+bx+c=0
16x²-6x-4=0
Sinθ=0.65
Sinθ=-0.28
Sin–1(0.65)=40.54°
θ1 = 40.54°
You wrote
$$\sin \theta = 6 \pm \frac{\sqrt{-6^2 - (4 \times 16 \times -4)}}{2} \times 16 $$
Did you mean
$$ \sin \theta = \frac{6 \pm \sqrt{(-6)^2 - 4\times16\times (-4)}}{2 \times 16}?\:$$
If so, use parentheses, like this:
[6 ± √[(-6)^2 - 4 × 16 ×(-4)]]/(2 × 16).
Better still, use LaTeX.
Anyway, ##x = 0.65## and ##x = -0.28## are nowhere near being solutions of the equation ##16 x^2 - 6 x -4 = 0##. In fact, if ##f(x) = 16 x^2 - 6 x - 4## we have ##f(0.65) = -1.1400## and ##f(-0.28) = -1.0656##.
Ray Vickson said:
Did you mean
Yes I meant that, sorry this is the first time I have tried to type an equation rather than write it.
Not sure what you mean there. It asks for the angles between 0° and 360°, can I not just Sin^-1(x) to get θ?
First you must correctly solve the quadratic. Then you can solve for all values of θ that work.
You obtained ##x=\sin \theta## by solving a quadratic equation; then you used the values of ##x## to get values of ##\theta##. Your values of ##x## are incorrect, so your values of ##\theta## are also incorrect.
Related to Solve acos²θ+bsinθ+c=0 for all values 0≤θ≤360°
What is the formula for solving acos²θ+bsinθ+c=0 for all values 0≤θ≤360°?
The formula for solving this equation is: θ = (1/a) * (arccos(-b ± √(b²-4ac)) + 2πn), where n is any integer.
What is the purpose of solving this equation?
The purpose of solving this equation is to find the values of θ that satisfy the given equation and fall within the given range of 0≤θ≤360°.
How do you simplify the equation acos²θ+bsinθ+c=0?
To simplify the equation, you can use the trigonometric identity cos²θ + sin²θ = 1. By substituting this identity into the equation, you can then solve for θ using the quadratic formula.
What are the steps for solving this equation?
The steps for solving this equation are:
1. Simplify the equation using trigonometric identities.
2. Use the quadratic formula to solve for θ.
3. Check the solutions to make sure they fall within the given range of 0≤θ≤360°.
4. If there are multiple solutions, use the formula θ = (1/a) * (arccos(-b ± √(b²-4ac)) + 2πn) to find all possible values of θ.
5. Round the solutions to the nearest degree if necessary.
What are some real-world applications of solving this equation?
This equation can be used to solve problems related to trigonometry, such as finding the angles of a triangle or the direction of a vector. It can also be used in engineering and physics to determine the position of an object or the angle of a force.
10K
