Solve Cascade System: Find z(t) from x(t)=u(t)
  • Thread starter Thread starter EvLer
    Signal
Two identical linear systems are connected in cascade, with the first stage output y(t) and the second stage output z(t). The problem involves finding z(t) given that the input x(t) is the step function u(t) and the output of a single stage with input tu(t) is (e^{-2t}-1)u(t). The discussion revolves around using the Laplace transform to analyze the system, where the Laplace transform of u(t) is 1/s. The user is uncertain about how to apply the relationship between input and output in the s-domain, particularly regarding the multiplication of transfer functions. A proposed approach involves determining the transfer function H(s) and using it to find the output z(t) by multiplying the Laplace transform of the input and then applying the inverse transform.
EvLer
Not even sure how to title this thread. I am saying honestly: we did not cover this in class but he gave us this in homework!
Two identical linear systems are connected in cascade. When the input signal to the first stage is x(t) the output signal from the first stage is y(t), the output of the second stage is z(t). If an input signal, tu(t) is applied to a single stage, the output signal of that stage is : (e^{-2t}-1)u(t) find z(t) if x(t) = u(t).
u(t) is a step function, u(t) = 1 if t >=0, and 0 otherwise;
what i was thinking of doing is converting the e...-expression to frequency domain and also the tu(t) and then seeing how input is modified to get the output and apply the same thing to u(t) which is the input into cascaded system, but TA said that there's multiplication involved in s-domain. I am sort of clueless...
If someone could explain or direct to a source, that would be very much appreciated, 'coz my book does not these examples and i don't even know what to seach for on Google! :cry:
maybe i am not making a connection to something...the latest we covered was circuit analysis in frequency domain doing nodal analysis.
sorry, should have given more detail: i understand laplace transform.
What i don't understand is how to make use of the given info that input is one function and output signal is a different function and what to do in s-domain (laplace "world") to apply that to u(t) which is the input signal to the 2-stage linear system.
EDIT: deleted my previous garbage...
EDIT: hold on...have another idea...would this work?:
H(s) = \frac{L(output)}{L(input)}
then when i find this factor i will have to multiply my given L(input) by it in s-domain and take L-1 to get the time-domain signal...
would that work?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
