TheFerruccio
- 216
- 0
Two Blocks Connected by Pulley System
[EDIT] sorry, I forgot to post the goal of this problem.
[EDIT] I wrote the question wrong.
At what point does the system come to rest?
What is the maximum distance it will fall?
Two blocks are connected by a rope and pulley system. The block on the right is released and is allowed to slide down the frictionless surface. The masses are specified, and their initial distance apart.
This is where I have the question. But, here are some diagrams that I made showing what I mean.
I have tried approaching it from two different methods.
1: Force-work relationships and momentum
2: Energy relationshipsI end up getting stuck in my attempts to solve this problem. It is deceptively simple, and I keep telling myself that it has a simple answer.
Let me give you the energy example of what I tried to do.
I said that the energy of the system must always be conserved, from the point of release to its energy equilibrium state. Thus, the sum of the potential and kinetic energies of both systems must equal.
I denoted a new constant, k, representing the length of the diagonal of the wire. I also denoted an angle from k to the diagonal, Θ. I found the vertical displacement of the left mass as k-a. The right mass has a vertical displacement d, which also relates to Θ.
So, my initial equation is:
Initial energy = 0 (what I defined as my 0 energy state, since I only care about the change of potential energy of the two masses)
0 = 2mg(k-a)-mgd-0.5(2m)\dot{k}^2+0.5m\dot{d}^2
This seems to get rather complicated fast. I can parameterize both k and d as:
d=k\sin{\theta}
and
\dot{d}=\dot{k}\sin{\theta}+k\cos{\theta}\dot{\theta}But, I am getting stuck from here. This seems to be exploding in complexity from something so simple. Is there a better, more elegant way to approach this?
I might be coming back with further questions, because I still do not have a solid grasp of when itis best to use force/momentum, or potential/kinetic energy when I am approaching these problems. I do not have a good grasp of when it is conserved and when it isn't. For instance, in this problem, since there are no impacts, and the problem seems to lack a distinct before/after to it, the energy of the system is conserved, which is why I tried to approach it from the energy perspective.
Should I use both methods to resolve some of the complexity? I do not have a good grasp of this. All of the class notes consist of very pure theory and vector analysis, so I have yet to strongly link the class notes to the actual applications.
d=k\sin{\theta}
and
