Solve Pulley Related Rotational Mechanics Problems: Concept Guidance
  • Thread starter Thread starter physixguru
    Concept Guidance
To solve pulley-related rotational mechanics problems, start by applying the principle of conservation of energy, where the loss in potential energy of the load equals the gain in kinetic energy of the pulleys and load. The acceleration of the system can be derived from the equation v^2 = 2ah, leading to a = v^2 / (2h). Calculating net torque is crucial, which involves using the moment of inertia and radius of the pulleys. Understanding constraint relations between the masses and pulleys is essential for determining tension in the string. Clear guidance on these concepts can significantly aid in solving complex problems effectively.
physixguru
how to solve pulley related rotational mechanics problems...
please guide me through...
the ques are of the kind...
mass is attached to a pulley which is further attched to larger pulley...
and the moment of inertia of both along wid their radius is given...
mass of the load is given...
asks to calculate tension between the wire joining the two pulleys...
what should be the intial cocept...
Have you tried
loss in PE of load = gain of KE of pulleys, load and trolley ?
Thanks Bro..shall Do It...
Note that the acceleration of the system (out of rest) when the load has dropped through a distance h is given by:
v^2 = 2ah
a = \frac{v^2}{2h}
hey thanks a million times frnz but that guidance is not enough for me to solve these kind of problems..
A string is wrapped around a wheel of moment of inertia=.20 kgm^2 and radius = 10 cm.
It goes through a light pulley of radius 5 cm and M.I=.10 kg m^2, to support a mass of 2kg.
Find the tension in the part of string joining the pulleys and and the acceleration of the block...
REALLY HAVING TROUBLE CALCULATING NET TORQUE AND CONSTRAINT RELATIONS..
PLS GUIDE ME THROUGH FRNZ..
IMAGE ATTACHED..
