Solve Trig Inequalities: Find x in [0,2pi] for 2cosx+1≤0
  • Thread starter Thread starter EL ALEM
    Inequalities Trig
To solve the inequality 2cosx + 1 ≤ 0 in the interval [0, 2pi], the critical points are found when 2cosx + 1 = 0, leading to cosx = -1/2, which gives x = 2pi/3 and 4pi/3. The solution involves testing intervals between these critical points: [0, 2pi/3), (2pi/3, 4pi/3), and (4pi/3, 2pi]. The inequality 2cosx + 1 < 0 is satisfied in the interval (2pi/3, 4pi/3), confirming that this is the solution. For inequalities with <, the endpoints are excluded, while for ≤, they are included, resulting in the final answer being [2pi/3, 4pi/3].
EL ALEM
find all values of x in the interval [0, 2pi] that satisfy the equation 2cosx + 1 less than or equal to 0
None.
for when 2cosx+1=0
cosx=-1/2
x= 2pi/3, 4pi/3
but what about the values for when 2cosx + 1 is less then 0? How to i fins those?
Since you have the roots - why don't you pick values between [0, 2pi/3), (2pi/3, 4pi/3), and (4pi/3, 2pi] to check? One or more of these intervals will give you your desired answer.
Ok so i found 2cosx + 1 < 0 at this interval (2pi/3, 4pi/3) , so would that be my answer?
If that is the only interval, then indeed it is! In these types of problems, you can always divide the set into intervals and find test points...
Thanks a bunch, one more question, if it was only less than instead of less than or equal to how would we divide the set into intervals?
Oh, well, technically speaking, if your inequality was \leq, then you should include the endpoints in the interval. If your inequality was &lt;, then you should exclude the endpoints. So what you're really working with is [2pi/3, 4pi/3].
Ok thanks.
