Solve Voltage Question: 3.3k & 4.7k Resistors
  • Thread starter Thread starter Agent
    Voltage
To calculate the percent of total voltage across a 4.7k resistor in series with a 3.3k resistor, the correct formula is to use the fraction of the 4.7k resistor over the total resistance, which is 4.7k divided by the sum of 3.3k and 4.7k. The result should then be multiplied by 100 to convert it to a percentage. A participant identified an error in their calculation, realizing they had mistakenly multiplied instead of adding the resistances. This highlights the importance of accurately applying series resistor formulas in voltage calculations. Understanding these principles is crucial for solving similar electrical problems effectively.
Agent
Hey, I'm stuck in one of the problems I was given. We just started it, so I'm a bit confused. It says: 3.3k resistor is in series with 4.7k resistor. Calculate the percent of the total applied voltage that would appear across the 4.7k resistor. I got this answer but I'm not sure if it is right. Thank you.
The 3.3k resistor gets this fraction of the total voltage drop:
<br /> \frac{{3.3k}}<br /> {{3.3k + 4.7k}}<br />
while the 4.7k gets this fraction:
<br /> \frac{{4.7k}}<br /> {{3.3k + 4.7k}}<br />
Don't forget to multiply by 100 to get percent.
- Warren
I know where I made the mistake. I'd multiplied instead of adding. I don't know why. Thank You.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
