Solving a Problem with Transformer Load Resistance and Source Resistance
  • Thread starter Thread starter RigelulZ
    Transformer Weird
The discussion revolves around solving a transformer problem involving load resistance, turns ratio, and source voltage. The user initially calculated the source resistance but arrived at an incorrect value of 77.4 Ohms. Participants suggested analyzing the voltage drop across the source resistance and the power relationship between the primary and secondary coils. Following this advice, the user recalculated using power and found the correct solution, emphasizing the importance of avoiding premature rounding in calculations. The exchange highlights the collaborative nature of problem-solving in physics.
RigelulZ
Weird Transformer Problem :(
"In the transformer shown in the figure below, the load resistance RL is 44.0 Ω. The turns ratio N1/N2 is 2.10, and the rms source voltage is ΔVS = 77.0 V. If a voltmeter across the load resistance measures an rms voltage of 26.5 V, what is the source resistance Rs?"
See attachment for Equation of Rs
I plugged in my values for the formula i got for Rs but got it wrong? I got 77.4 Ohms
Does anybody know what I'm doing wrong? Because i sure don't.
Any help will be greatly appreciated, thanks in advance!
-Rígel
How are you analysing the problem?
Can you determine the voltage drop across the source resistance? Can you determine the power in the secondary coil? How is that related to the power passing through the primary coil?
AM
AM
Wow, you were absolutely right, i did it through power like you instructed and it worked like a charm.. I also learned not to round too soon into the problem.. :/
Thank you!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
