Solving for 3 variables in projectile motion problem
The discussion focuses on solving a projectile motion problem involving a dart thrown at a 30-degree angle from a height of 1.6 meters, landing 20 meters away. Key equations for vertical and horizontal motion are provided, including the effects of gravity on the dart's trajectory. Participants express uncertainty about isolating variables and understanding the physical meaning of initial height (y1) and final height (y). It is suggested that the initial speed can be expressed in terms of its horizontal (vx) and vertical (vy) components using trigonometric relationships. The conversation emphasizes the need to apply the equations systematically to find the initial speed, maximum height, and impact speed of the dart.
babacanoosh
A dart is thrown at a 30 degree angle above the horizontal from a height of 1.6 meters. It hits the ground 20 meters away.
a) find the initial speed?
b)what is the maximum height reached by the dart (relation to the ground)?
c)what is the speed of the dart as it hits the ground?
y= y1 + Vy1t - 9.8t^2
Vy = Vy1^2 - 2(9.8)(y - y1)
Vy= Vy1 - 9.8t
x1 = 20
x=0
t=?
a=-9.8
y1=?
y=?
I understand that I most likely need to use the following three equations in order to isolate one variable. I am not sure which variable/how to.
Do you know what y1 (physically) means? Because its value is given in the problem.
So is that of y.
If you call the initial speed v, then you can rewrite v in terms of vx and vy and the angle (30 degrees).
