Solving for Angular Velocity of Rod: 6.8 rad/s
The discussion revolves around calculating the angular velocity of a rod connected to a flywheel rotating at 6.8 rad/s. The initial attempt involved using the velocity equations for points B and C, but the user encountered too many unknowns. It was suggested that the rod's motion relative to the flywheel complicates the use of standard equations for rigid bodies. The key insight is to focus on the rod's angular velocity around its fixed point, considering the stationary nature of points O and D at that instant. This approach simplifies the problem and aids in finding the solution.
uncensored188
The flywheel is rotating with an angular velocity of = 6.8 .
Determine the angular velocity of rod at the instant shown.
http://postimage.org/image/lfypabekb/
(1) V_B= ω x r
(2) V_C= V_B + ω x r_C/B
I do r times ω to get the velocity of B to be
-2.04i
I then plug into equation (2)
and i get (V_cx)i + (V_cy)j = -2.04i -1.5ωj
there are too many unknowns,
im guessing i have to use the length of DC and its angle somehow but i don't know how
THANK YOU
You have got the right value for the velocity.
Your second relevant equation is the velocity at a point in a rigid body (Vc), in terms of the velocity at some other point (Vb). But the rod is moving with respect to the flywheel, so the entire system is not one rigid body, so I don't think you can use this equation here.
Also, I think we can assume the question wants you to calculate the angular velocity of the rod around the point at which the rod is fixed. To calculate this is not very complicated. just think of the system at that particular instant in time.
O and D are stationary points. They have no acceleration nor velocity. See if that helps
