Solving for cos 2v and sin 2v: Quick Guide
  • Thread starter Thread starter Maria
    Cos
To solve the equations cos 2v = cos v and sin 2v = sin v, double angle formulas are applied. For cos 2v, using the identity cos 2v = cos²v - sin²v leads to the conclusion that v must equal 0, as this satisfies the equation. The second equation, sin 2v = sin v, can also be approached similarly, but it is noted to be more complex. The discussion emphasizes the importance of selecting values for t within the range of [-1, 1]. Overall, both equations can be solved through trigonometric identities and algebraic manipulation.
Maria
How do I solve these two:
cos 2v = cos v
sin 2v = sin v
Double angle formulas, e.g. sin 2x = 2(sin x)(cos x)
So your second equation becomes:
2(sin x)(cos x) = sin x
cos2v=2(cosv)^2-1
t=cosv and solve equation.
The second I remmember you already asked and were properly answered by matt and mods, so why "repeat" it ?:confused:
[dont forget to choose only t's in the range [-1,1] only]
(1) cos 2v = cos v
(2) sin 2v = sin v
Does it go like this?
(1) cosv = cos2v = cos( v + v) = cosv cos v - sinv sinv
= cosv [cos v] - [sinv sinv] = cosv[ 1] - [0] if it is to equal cosv, as given.
Therefore need: [cosv] = 1 and [sinv] = 0; so v = 0.
[PS: Your teacher may prefer Motifs' suggestion where you solve a standard quadratic equation.]
(2) is similar, but more interesting. Good luck.
