Solving for Distance of a Rotating Wheel
  • Thread starter Thread starter julz3216
    Rotating Wheel
The problem involves calculating the distance traveled by a point on the edge of a rotating wheel that accelerates uniformly from a specified initial to final angular velocity over a given time period. The subject area includes rotational motion and angular kinematics.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of angular kinematic equations and the need to convert angular velocities from rpm to radians per second. There is an exploration of calculating angular acceleration and the total angle rotated during the acceleration period.
Some participants have provided guidance on unit conversion and the correct application of formulas. There is an acknowledgment of potential errors in calculations and the importance of using consistent SI units. Multiple interpretations of the calculations are being explored, but no consensus has been reached on the final answer.
Participants note the importance of maintaining SI units throughout the calculations, with specific reference to the diameter of the wheel being in meters rather than centimeters.
julz3216
A wheel 31.8 cm in diameter accelerates uniformly from 242 rpm to 380 rpm in 7.66 s. How far will a point on the edge of the wheel have traveled in this time?
angle = initial angle +angular velocity(t) + .5(angular acceleration)(t)
w=initial angular velocity +angular acceleration (t)
and s=R*angle
i tried plugging into the equations but i really don't know what to do
Not quite.
θ = θo + ω*t + 1/2*α*t2
Where θ is in radians.
And there are 2π radians in a revolution.
First convert your ω's to radians/sec from rpm and figure α and then you can figure your θ.
To find distance ... x = θ *r
I converted to rad/sec so its 25.34 and 39.79
I found a = (39.79-25.32)/7.66 =1.886
then I used θ = θo + ω*t + 1/2*α*t2
and did θ = 0 + 25.34*7.66 + 1/2*1.886*7.66 = 249.435
So i got x=θR = 249.435(15.9) = 3966.01
But this is wrong, is there something else I need to convert or calculate?
Without doing any other math I would note the diameter is .318m.
Always, always stay in SI units wherever possible.
Oh ok, that's what I did wrong. I got it. Thank you!
  • · Replies 44 ·
  • · Replies 19 ·
  • · Replies 25 ·
