Solving for I2 in a Circuit: What Am I Doing Wrong?
  • Thread starter Thread starter radji
    Emf Rules
The original poster is attempting to solve for three currents (I1, I2, I3) in a circuit using loop equations and junction rules. The problem involves analyzing the circuit based on a provided diagram and equations related to current and voltage.
  • The original poster describes their approach of expressing I1 in terms of I2 and using loop equations to derive I2. Some participants question the setup of the loop equations and the identification of junctions in the circuit.
Participants have provided feedback on the circuit setup, noting that the system may be overdetermined and suggesting corrections to the identification of nodes. The original poster acknowledges these points and seeks to verify their loop equations before proceeding with calculations.
The discussion includes constraints related to following a specific circuit diagram for a lab experiment, which influences the approach to solving for the currents.
radji
I am attempting to solve the circuit for three currents (I1, I2, I3). I am starting with I1 in terms of I2, then using a third equation to solve for I2 in terms of E and R. I wrote my loops at the bottom of the page. I am using Loop 1 @ B, Loop 2 @ B, and Junction at B to solve for I2.
7S4X1pl_hjhU4Efbj77kr9gM8V_PBS5YUbUU4wvEnjk6g_bVe6lepzS2ZXebsp0c9NwTkzuBm7MV4Llpc=w1425-h1855-no.jpg
ΣIin=ΣIout
∫dv=0
Page 2 has all my algebra to solve for I2 first. I reversed the sign of Loop 3 at B, but I don't think that is what is throwing off my answer. I have a measured I2 value to compare against and my answer is nowhere near it. Not sure what I am doing wrong.
-p7AwpuIR9xDgpILR7q510VbIVgymIFQ-HFVjETV_a_xf3_vR4U7LYLAKK1MAqq8afiJYqKgYGZtxUJlw=w1425-h1855-no.jpg
The first issue is that A is not a junction. Also the system looks over determined. There are only two loops so you only need two currents.
Thank you for your reply. This is a lab experiment so I have to follow (i.e. use) the circuit diagram I am given. You are absolutely right, I need only the two loops and one junction at B to solve for the 3 currents. I am more looking to see if my loop equations are setup correctly. Then I can move on to what I did wrong in my calculations.
Okay, in that case the nodes A and C are incorrect.
Thank you for your observation. I was able to correct the nodes and solve for each unknown current. Even found out how to solve using only one node!
