Solving for the Coefficient of Kinetic Friction: An In-Depth Explanation
To find the coefficient of kinetic friction, start by applying the conservation of energy principle, equating the kinetic energy at the bottom of the ramp to the potential energy at the top. The work done by friction to stop the suitcase can be calculated using the distance it travels after reaching the bottom. By determining the frictional force required to stop the suitcase, you can then solve for the coefficient of kinetic friction using the relationship between frictional force and normal force. Understanding these steps will clarify the process of calculating the coefficient. A thorough grasp of these concepts is essential for solving the problem effectively.
Vinegar
PE=mgh, KE=1/2mv^2
In picture.
What's confusing me is how to find the kinetic friction without its coefficient. I've attempted multiple solutions on paper, and I can't get anywhere with it. I know that at the bottom of the ramp, the KE is equivalent to the PEi of the ramp, and I know the distance it stops at.
I just need an in-depth explanation of the steps taken to solve for the coefficient. If I can find this, I'm set. I'm great at physics, but I am having trouble grasping this concept. Help is appreciated!
Welcome to PF!
Since you know the suitcase's kinetic energy at the bottom of the ramp (from conservation of energy), you know how much work has to be done in order to bring it to a stop. You also know over what distance this work was done. Therefore, you can solve for the frictional force that must have done said work on the suitcase. Once you know the frictional force, you can easily solve for the coefficient of kinetic friction, since you know everything else (aside from the coefficient itself) that that frictional force depends on.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
