Solving for time when given distance and acceleration,
  • Thread starter Thread starter jkmjkm
    Acceleration Time
To determine the time it takes for a car to cover 125 meters while accelerating at 4.0 m/s² for 9.0 seconds, the equation s = v0t + 1/2at² can be used. Although the quadratic formula is mentioned, it is not necessary for this problem, as it can be solved directly using basic physics principles. The initial velocity (v0) needs to be inferred from the context, as it is not explicitly provided. The discussion emphasizes the importance of understanding foundational algebra concepts for solving physics problems. Ultimately, the user successfully solved the problem using a simplified approach.
jkmjkm
Problem: How long will it take a car to cover a distance of 125 m if it accelerates at 4.0m/s^2 for 9.0 sec?
I'm in an intro to physics course. Our teacher has taught us nothing about quadratics yet. He has, in fact, taught us very little. Friends have tried to teach me how to solve this question using the " D = .5*a*T^2" equation, but I just can't grasp it. Since using the quadratic formula hasn't even been mentioned in class, I feel like that's the not the way he wants us to solve it. Is there another way to solve this question?
Solution attempt: 1/2at^2 + v0t - s = 0 is all my friends have given me. I am completely lost.
Welcome to Physics Forums.
Before providing some help, I just need to mention a few things. These are meant to both help you in your physics class and any future science classes, as well as some guidelines for getting help at our forum, so I hope you take them in the constructive spirit intended.
1. By the time you are taking physics, it is pretty much expected that you know what you have been taught in your algebra and geometry classes. This includes knowing about the quadratic formula.
2. Please don't post in all-bold font for your entire post. As one of the forum moderators, I have taken the liberty of editing it to remove most of the bolding.
3. Please leave the homework template intact in future posts (the thing that says "1. The problem statement", etc. etc.)
That being said: yes, the equation "1/2at^2 + v0t - s = 0 " works for solving this problem. But it is usually given in the form
s = v0t + 1/2at^2​
At any rate, you need to think about what the value of v0 is in this problem. No, they don't tell you explicitly in the problem statement, but common sense should help you out here.
Hope that helps, and again welcome to PF.
I just noticed you posted another equation, "D = .5*a*T^2". You don't actually need the quadratic equation here, you can solve that equation for "T" without the quadratic equation. Post back if still need help with that.
Is there a way to delete this thread? Because I've already solved it using t = the square root of d / a...
I'm in a pre-health program, so we're being taught the very basics and then we're getting into the more "involved" stuff later in the semester. We haven't learned about quadratics in math yet, so we wouldn't be using quadratic formulas in physics.
