Solving Inclined Plane FBD Issues with Components
  • Context: Undergrad
  • Thread starter Thread starter Kugan
    Fbd General
1 reply · 4K views
Kugan
Ok so here is the issue I'm having:
For problems with inclined planes I have always broken the Fg force down into its components:
Fgy= mgcos(theta)
Fgx = mgsin(theta)
Usually the Fnety= Fgy+ Fn(there is no motion in the Y direction for let's say a car going around a banked curve) Fnety=0 so we can't just say -Fgy= Fn, so Fn = -m(-g)cos(theta) finally arriving at Fn= mgcos(theta)
If however I were to break the normal force vector into components and not the Gravitational force I get: Fn= mg/Cos(theta)
Fny= Fncos(theta)
Fnx = Fnsin(theta)
Fnety = Fny+ mg;
0 = Fny+ mg;
Fny= mg;
Fncos(theta)= mg;
Fn = mg/ cos(theta)
Can someone clarify why, I get two different normal force vectors depending on whether I use the Fg force or the Fn force to orient the axis and break the vector into the components ?
Thank you.
Fgy= mgcos(theta)
Fgx = mgsin(theta)
Here, let me tidy up:
If you put your axis so +y is normal to the slope, +x points down the slope, and the slope has angle ##\theta## to the horizontal (as the usual setup) then you will have, in the absence of any other, applied, force:
* a normal force ##\vec{N}=N\hat{\jmath}##,
* a weight (gravitational force) ##\vec{w}=mg\sin(\theta)\hat{\imath}-mg\cos(\theta)\hat{\jmath}##; and
* a friction force ##\vec{f}=-\mu N \hat{\imath}##
(note - I find it is useful to avoid subscripts where I can.)
For a car going around a banked curve, there is a net unbalanced force acting radially inwards... so it is not correct to write that ##F_{net}{}_y=0##
In this situation it may be more useful to adopt a different coordinate system. i.e.
Fny= Fncos(theta)
Fnx = Fnsin(theta)
Fnety = Fny+ mg;
0 = Fny+ mg;
Fny= mg;
Fncos(theta)= mg;
Fn = mg/ cos(theta)
If you orient your axis so +y = ##-\vec{w}## (i.e. "upwards") and +x pointing at the center of the turn (i.e not into the ground): then the three forces resolve into:
* a normal force ##\vec{N}=N\sin(\theta)\hat{\imath}+N\cos(\theta) \hat{\jmath}##,
* a weight (gravitational force) ##\vec{w}=-mg\hat{\jmath}##; and
* a friction force ##\vec{f}=-\mu N\cos(\theta)\hat{\imath}+\mu N\sin(\theta)\hat{\jmath}##
Thus, ##F_{net}{}_y = N_y-mg+f_y=0 \Rightarrow N_y=mg-f_y##
For the sake of an argument - say that ##f_y=0##, then we recover your:
##N_y=N\cos(\theta)=mg \Rightarrow N_y=mg/\cos(\theta)##
So let's see what the issue is:
Well, clearly, you shouldn't. The trouble is that you are comparing situations that are not equivalent. I suspect you are treating the normal force as an fixed applied force rather than a dynamical force.
Lets take the case of a block accelerating down a frictionless incline ... in that case, the forces normal to the slope should cancel.
We would expect to find that ##N=mg\cos(\theta)## using either coordinate system.
Using gravity to set the coordinates - it is not correct to write ##N\cos(\theta)=mg## because some of the gravity force must be unbalanced to give the acceleration down the slope. In fact ##\vec{N}## will always work so that ##\vec{N}+\vec{w}## will point down the slope.
Now take the case of a block sitting stationary on a slope with friction.
In this case normal components will cancel and so will perpendicular components.
We'd expect to find that ##N=mg\cos{\theta}## and ##\mu N=mg\sin(\theta)## no matter what coordinates we use.
I think you should be able to do it from there.
