Solving Lens Image Problem: Where is Image Formed?
  • Thread starter Thread starter jmb07
    Image Lens
The discussion focuses on calculating the image distance for an object in front of a convex mirror. The initial calculation using the formula Di = (Doxf)/(Do+f) yielded an incorrect image distance of 5.23 cm instead of the expected 3.41 cm. The focal length for the convex mirror was correctly identified as 4.9 cm, derived from the radius of curvature. The user initially questioned the relevance of the object's height in the calculations but later resolved the issue independently. The thread highlights the importance of accurately applying the mirror formula and understanding the properties of convex mirrors.
jmb07
An object 1.95 cm high is placed 11.2 cm in front of a convex mirror with a radius of curvature of 9.8 cm. Where is the image formed??
So i know Di= (Doxf)/(Do+f)...(11.2 x 9.8)/ (11.2 + 9.8) = 5.23 cm
However, the correct answer is 3.41 cm
What am i doing wrong here? I know that the 9.8 may not be the focal length but how do i relate the height to the focal length??
Focal length of the convex mirror = R/2 = 9.8/2 = 4.9 cm.
do i even need to use the height of the object??...if so how?
nevermind i got it! thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
