Solving Lever Calculations to Help Son
  • Thread starter Thread starter Alan Butcher
    Calculations Lever
The discussion focuses on solving lever calculations involving a 5-meter lever, a weight of 300 kg, and a force of 100 kg. The key formula for determining the distances from the fulcrum is based on the principle of torque equilibrium: F1D1 = F2D2, where F1 and F2 are the forces applied, and D1 and D2 are the respective distances from the fulcrum. Given that D1 + D2 equals 5 meters, one can express D2 as 5 - D1, allowing for the calculation of D1 using the torque equation.
  • Understanding of basic physics principles, particularly torque and levers.
  • Familiarity with algebraic manipulation to solve equations.
  • Knowledge of force and weight measurements in kilograms.
  • Concept of equilibrium in mechanical systems.
  • Study the principles of torque and equilibrium in levers.
  • Learn how to apply the lever arm formula in practical scenarios.
  • Explore advanced applications of levers in mechanical engineering.
  • Investigate real-world examples of lever systems in physics experiments.
This discussion is beneficial for students learning physics, educators teaching mechanics, and anyone interested in practical applications of lever systems in engineering and everyday life.
Alan Butcher
My problem (trying to help an ay last keen son)-a lever 5m long, a weight of 300kg, a force of 100kg.
The question says describe?
I am trying to work out the distance from the end of lever to fulcrum
or in other words where the fulcrum should lie.
tried formula which has gone to course with son but it gives L over little l = force over effort?
Can you assist please?
I feel there must be some better formula.
Look at the torques involved in a lever. To be in balance about the fulcrum, the torques must be equal. In other words:
F_1 D_1 = F_2 D_2
where the Fs are the two forces applied to the lever and the Ds are the distances from the fulcrum. You are given the forces. Hint: What must those two distances add to?
ah ha these two Ds add up to my 5m lever right?
ok
F1D1 = F2D2
but D1+D2 = 5m
so
mmm
after 45 years away from school
If in the above formula I know that D1 and D2 add up to 5m how do I find what D1 and D2 are?
If you know both distances add up to 5m, you can say one is D1, and the other must then be D2=5-D1. Put that into your equation and you can solve for D1.
9K
  • · Replies 65 ·
