Solving Pulley Questions: Mass, Friction, and Tension Calculations
To solve pulley questions involving blocks and friction, it's essential to apply both force equations for each mass and a torque equation for the pulley. The tension in the string differs on either side of the pulley due to its mass, which creates a net torque necessary for acceleration. If the blocks were to reach a state where the net force is zero, the tension would not equalize; instead, the acceleration remains constant based on the system's parameters. Understanding the dynamics of the system, including mass, angle of incline, and friction, is crucial for accurate calculations. Therefore, the tension will vary as long as the system is in motion.
semc
A block of mass 2kg and 6kg are connected by a massless string over a pulley in the shape of a solid disk having radius R=0.25m and mass 10kg.These blocks are allowed to move on a fixed wedge of angle 30\circ the coefficient of kinetic friction block is 0.36. Find the acceleration of the blocks.
Hmm how do you solve questions that involve pulley? The second part of the question ask to find the tension in the string and the tension is different. Why is that so? Shouldn't the tension be same since the string is connected?
In addition to your force equations for each mass, you'll need a torque equation for the pulley.
The tension would be the same throughout the string if the pulley were massless, but since the pulley has mass the tension on either side of the pulley will be different. (If the tension was the same, there would be no net torque to accelerate the pulley.)
So if the blocks keep sliding to a point whereby the acceleration is zero then the tension will be the same? Thanks doc :smile:
I'm not quite sure what you mean. As the blocks slide, the acceleration remains constant. (Until one of the blocks slams into something, of course.)
I mean will there be a point where the net force acting on the blocks are zero so the tension will be the same?
No. The net force and the resulting acceleration is determined by the masses and the angle of the incline. By setting up and solving your force equations (from Newton's 2nd law) you'll be able to determine the acceleration. For a given set of conditions, the acceleration is constant.
