Solving Series RLC Circuit Problems: Input/Output Equations & Diagram
The discussion focuses on solving a series RLC circuit problem, specifically finding input/output difference equations for various circuit components. Participants emphasize the importance of using Kirchhoff's Voltage Law (KVL) and suggest expressing voltages and currents as functions of the capacitor voltage, v_C. One user shares their initial attempts at forming equations but struggles to derive satisfactory results. Others encourage showing work for further assistance and provide hints for rewriting equations to achieve a second-order equation in v_C. The conversation highlights the necessity of following forum rules by demonstrating progress to receive more detailed help.
Raihan
Please help me to solve this RLC circuit problem. I am completely confused.If you give me the direct answer it would be much appreciated.
For the series RLC circuit in Figure, find the input/output
difference equation for
1.y(t)=v_{R}
2.Y(t)=i(t)
3.y(t)=v_{L}
4.y(t)=v_{C}
I have attached the Circuit diagram in a .jpg file.
You must show your own work in order for us to help you (PF homework forum rules). Would KCL or KVL be the best way to start?
Hey first I tried taking the KVL around the loop
something like
-x(t) + v_c(t) + v_L (t) + v_R (t) = 0----(1)
replaced v_L(t) with first order Ldi_L(t)/dt and make an equation for
v_C(t)
and then as its in series I tried to write a function for
i_L(t) = \frac {v_R (t)} R------(2)
and for [ tex ] v_R(t)/R=C \frac {dv_c(t)} {dt} [/tex]----(3)
Then tried sub (3) in (1)
and got
v_C(t) = x(t) - \frac {L} {R} dv_R(t)/dt - v + R(t)----(4)
and then tried sub it i eqn 3. and didnt come up with a satisfactory result.
Please help.
Thanks
something like
-x(t)+v_c(t)+v_L(t)+v_R(t)=0----(1)
v_C(t)
i_L(t)=v_R(t)/R------(2)
and for v_R(t)/R=Cdv_c(t)/dt----(3)
and got
v_C(t)=x(t)-\frac {L} {R}dv_R(t)/dt-v+R(t)----(4)
Please help.
Thanks
In series circuits you should always use v_C as the independent variable (and i_L in parallel circuits).
Since the current is the same for all elements, write v_L and v_R as functions of the current. Finally write the current as a function of v_C.
Thank you very much for your info SGT, would you please help little bit more.
Make the substitutions I suggested in your equation 1. More help will only be provided after you show some work.
I tried And I am not going anywhere. please help
Post what you have done and I will give you more hints.
solution so far
heres what I got so far.. please help after this point..
thanks
In the second equation don't use the integral term. Keep it as V_C(t).
In the two other terms replace i by C\frac{dV_C}{dt}. You get a second order equation in V_C
Would you please not mind to show me please. I have tried this so far. please help after this.
thanks
The rules of the forum are that you must do your work. We only give hints. Rewrite the second equation with the suggestions I made and post it here.
The easiest way to solve any RCL circuit with an input vs(t) is by a difference equation.
Let curr= (q1-q0)/dt
q2=2.*q1-q0 + dt**2*( -q1/(L*c) -(R/L)*curr +vs(t-dt) ).
Then everything else follows ,
Vc(t) = q2/C , VL = L * ( q2-2*q1+q0)/dt^2 , VR = R*(q2-q1)/dt
SEE http://www.geocities.com/serienumerica/RCLfree.doc
