What Are Key Reflection and Loss Concepts in Microwave Engineering?
Key concepts in microwave engineering include the generalized reflection coefficient, which allows analysis of voltage reflections at various points along a transmission line, not just at the load. Shunt conductance in circuit theory is represented by shunt resistance, linking to power loss calculations. Conductor losses are defined as I^2R losses, while dielectric losses stem from the material's complex permittivity. Mismatched generator and load impedances lead to reflections at both ends, complicating the analysis. A lossless transmission line is characterized by only inductive and capacitive components, whereas a lossy line includes resistive and conductance elements, indicated by a non-zero propagation constant.
better361
Hey guys, I am currently self studying some microwave engineering through Pozar's textbook, and I have a couple of conceptual questions.
1.What is the point of defining a generalized reflection coefficient \tau(0) e^{-2j\beta l} if real reflections happen at boundaries?
2. Is there an analog to shunt conductance in basic circuit theory?
3. What exactly does it mean that we have small conductor and dielectric losses?
4. Pozar says that because the generator and load are mismatched, reflections will occur at that boundary also. But later he says the voltage on the line is just: (V_o)^{+}(e^{j\beta l}+\tau_l e^{-j\beta l}), which seems to imply the voltage is only due to initial wave and one reflected wave, which is at the load.
5. How do I tell if a line is lossless or not, without being given transmission line parameters?(Here is an example from the book: A radio transmitter is connected to an antenna having an impedance 80+j 40 ohms with a 50 ohms coaxial cable...)
Likes berkeman
1. The reflection coefficient at the load is the ratio of the reflected voltage to incident voltage at the load. But there are times when for various reasons, we want to know what the ratio of the reflected voltage to incident voltage is at other places along the transmission line. So, we have a generalized reflection coefficient.
2. Shunt conductance is a shunt resistance. Well, if you have a shunt resistor, then you can express it in terms of its resistance or its conductance.
3. Conductor losses are ##I^2 \times R## losses. Dielectric losses refer to power losses in dielectrics due to the complex permittivity of the dielectric. The dielectric has a loss tangent.
4. If the generator and load are both mismatched, you will have reflections at both boundaries. This becomes a very complex problem. Often, the goal is to make sure that the generator is matched to the transmission line. Then you only have to concern yourself with the load and the transmission line.
5. If a transmission line is lossless, then its equivalent lumped circuit model would only include a series inductor (lossless) and a shunt capacitor (lossless). If a transmission line is lossy, then its equivalent lumped circuit model would include a series resistor and a series inductor and a shunt conductance and a shunt capacitor. The propagation constant of a lossy line is ## \gamma = \alpha + j \beta##. For a lossless line, ## \alpha = 0##.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
