Sorry I need so much help, my tutor is done for the semester
  • Thread starter Thread starter Kris1120
    Semester Tutor
The discussion revolves around a physics problem involving a spring and a block. The spring constant is calculated using the formula k = mg/x, yielding a value of approximately 26.89 N/m. For the angular frequency of the block's vibrations, the formula omega = sqrt(k/m) is applied, resulting in about 7.83 rad/s. Participants clarify the importance of considering acceleration at the moment the block comes to rest, emphasizing the need for conservation of energy in the analysis. The conversation highlights common pitfalls in understanding spring dynamics and encourages revisiting foundational physics concepts.
Kris1120
A spring is hung from the ceiling. A 0.483-kg block is then attached to the free end of the spring. When released from rest, the block drops 0.176 m before momentarily coming to rest. (a) What is the spring constant of the spring? (b) Find the angular frequency of the block's vibrations.
(a) F = kx
(b) omega = sq rt(k/m)
(a) k = mg/x
= (0.483 kg)(9.81 m/s) / 0.176 m
= 26.8943 N/m
(b) sq rt( 26.8943 N/m / 0.4383 kg) = 7.83329 rad/s
well your logic looks right, i did the calculation for part a and got 26.92, not sure if that's where your mistake is...
(a) F = kx
Hi Kris1120! :smile:
Nooo … :frown:
The acceleration is not zero, is it?
Use conservation of energy. :smile:
oooohhhh yeaaaa... i forget a lot after 2 months of no physics... acceleration is at a max when the block is momentarily not moving
