Calculating Sound Wave Intensity and Decibels 10.0m from Source
The discussion focuses on calculating the intensity of sound and its decibel level at a distance of 10.0 meters from a source emitting 5.0 mW of acoustic power. The intensity is determined to be 4 x 10^-6 W/m^2, derived from the power divided by the surface area of a sphere with a 10 m radius. The sound level in decibels at this distance is calculated to be 66 dB, using the formula L=20log_10(p1/p0), where p1 is the acoustic pressure and p0 is a reference pressure of 2 x 10^-5 Pa. The calculations illustrate the relationship between power, intensity, and sound level in acoustics. This provides a foundational understanding of sound wave behavior in a spherical distribution.
jamessmith
A source of sound emits 5.0 mW of acoustic power uniformly in all directions.
1. Calculate the intensity of this sound wave 10.0 m from the source.
2. Find the sound level in decibles 10.0 m from the source.
Answers:
1. 4 x 10^-6 W/m^2 ---- I don't know how to get this answer.
2. 66 dB --- I don't know how to get this answer.
I don't really feel like calculating, but the idea behind this problem is very simple.
Consider a spherical loudspeaker, which probably doesn't exist, but it would definitely emit the sound in all directions. Thus, the acoustic wave would form a sphere. The power, that the wave carries with itself is constant, in this case it's your 5mW. The intensity you are supposed to calculate is the amount of power per square meter. 10.0m from the source the acoustic wave forms a sphere with radius=10 m. Now you just need to calculate the area of such spere and you should get the correct answer.
Now, having calculated that, you have to know what sound level (in dB) is. Mathematically, the equation is L=20log_10 (p1/p0). p1 is the acoustic pressure of the wave. You have been given the acoustic power of the wave. Now, according to the deffinition, P=W/t, but W=F*S (excuse this mid-school notation :P), hence P=F*S/t; but S/t=v, which is the velocity of the acoustic wave in the air-constant. Thus F=P/v. To get the pressure, divide by the area again. p0 is the refference value (dunno what it's called in English) equal to 2*10^(-5) Pa.
Hope it helps,
greets
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
