Sources for Physics Research Paper on Rotational Blade Motion on Helicopter
Rayla
TL;DR Summary: I am writing a research paper on the rotational motion of the blades of a helicopter. Does anyone know of any good reliable sources for articles, videos, or research papers on this topic?
Hi!
I am writing a research paper on the rotational motion of the blades of a helicopter. I have just started studying for my associate's in science degree and have completed PHY-200. I used the University Physics Volume 1 textbook by OpenStax. I plan to utilize chapters 10 and 11 in my paper since those chapters are related to rotational motion, along with other chapters that have rotation in them. Does anyone know of any good reliable sources for articles, videos, or research papers on this topic? I was told about arxiv.org. This is the first physics research paper I've had to write. This is my thesis (I am still working on it): "My proof, not experiment, is an examination of propeller design in helicopters and reasons behind the choices made; and how rotational motion is involved in this."
Basically, I want to write about helicopters and rotational motion but have no idea what to read for this.
Thank you!
If I didn't explain my question well, please tell me. :)
Welcome to PF.
Often when you want to focus your search on research articles and similar sources, you can use Google Scholar for the search. You can see the search I did in the screenshot below -- maybe try that search to get you started, and you can refine your Google Scholar search as you get closer to what you are looking for.
Likes Lnewqban and .Scott
Welcome to PF.
Thank you!!
Likes berkeman and Lnewqban
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
