Special relativity problem (momentum and velocity)
Quazswed
A particle traveling at 8 E7 m/s is accelerated so that its momentum doubles. What is the final velocity of the particle?
p=ym0v
y= 1 / sqr(1-(v/c)^2)
p2= 2(p1)
Where p2 is the final momentum and p1 the initial
For the initial velocity gamma=1,0376
p1 is therefore, calculated with m0=1 (I put it this way thinking it was not relevant to the problem, and it was meant to be eliminated when finding p2) 83008000 kg m/s
I tried to compare the two equations for the relativistic momentum but the best i came up with was that (v2)x(y2)=166016000 m/s
Given that the result written on the book is 1,5 E8 m/s, y2 must be 1,107
because y2= 2y1v1 / v2
But for a velocity of 1,5 E8 m/s (0,5c), the dilatation factor is 1,154
I really don't know, I keep trying the same method, I can't see a different way to resolve it
Sorry for the bad english, not my lenguage
Thanks to everybody in advance
Quazswed said:
A particle traveling at 8 E8 m/s
That can't be right. What is the speed?
uops, I'm sorry, i meant E7
anyway I used 8 E7 in the equations
Also, edited in the first post, thanks for pointing that out
Assuming your arithmetic is correct (I didn't check) write the left hand side entirely in terms of v2. Then solve for v2.
2y1v1 is = 166011471 m/s, I think it's correct now
so
2y1v1 = 166011471 m/s = k
y2= 1 / sqr(1-(v2/c)2)
v2 / sqr(1-(v2/c)2) = k
v2^2 = k^2 - k^2(v2/c)^2
(k^2/c^2 +1)v2 = k^2
v2 = sqr( k^2 / (k^2/c^2 +1))
which is 145254607 m/s, it's so close to 150000000 m/s
Is this an error caused by bad arithmetic or something else, more important?
It's not an error. The book just rounded off to 2 digits.
Seems like I was too pessimistic then :)
Thank you very, very much for your help
