How do I solve for the specific heat in a heat transfer problem?
The discussion revolves around calculating the specific heat of a metal alloy after it is submerged in water. A user presents a problem involving a 25g block of alloy at 215°C dropped into 85g of water at 22°C, resulting in a final temperature of 37°C. Confusion arises over the correct application of heat transfer equations and sign conventions. Participants clarify that the heat lost by the alloy equals the heat gained by the water, emphasizing the importance of using consistent units and understanding that heat transfer can be treated as positive values for both substances. The conversation concludes with a consensus on the method to solve the problem, highlighting the need for careful attention to temperature changes and conventions.
mathzeroh
how're all the fine scientists feeling today?
well i jst had a question regarding my specific heat & Co. homework.
ok here it is: "When a 25g block of metal alloy at 215 degrees celcius (i don't know how to make that round degree symbol on here) is dropped into 85g of water at 22 deg.C, the final temperature is 37 deg.C. What is the specific heat of the alloy?
i worked it out 2 different times and got 2 different answers each time. :cry: :rolleyes:
once i got 15 J/(g*degrees Celcius) and then the second time i got 1.2 J/(g*degrees Celcius)
any help at all appreciated! thanks in advance!
Chemistry news on Phys.org
Okay.I don't use sign conventions for given and received heat,so i'll simply write
Q_{\mbox{given}}=m_{\mbox{alloy}}c_{\mbox{alloy}}(215-37)
Q_{\mbox{received}}=m_{\mbox{water}}c_{\mbox{water}}(37-22)
Set the 2 #-s equal and then solve for the unknown.
Daniel.
P.S.Pay attention with the units.I'd advise u to use SI-mKgs.
wouldnt it be (37-215) because delta T is always t final minus t initial??
and what did you mean by SI-mKgs ? :confused:
Nope,i don't use convention signs.The heats are always positive and equal...(in this 2 body thermal interraction).
SI-mKgs from Système International-metre,Kilogramme,sécond .
Daniel.
oh.
well when heat is negative, it meant that its lost, right? that's what i was thought. let me get another crack at it with what you said. but i don't understand why u would have to set them equal together, since Q of water plus Q of metal alloy should equal 0 right?
A positive number can never be equal to a negative number. So, what Dexter is doing is simply making sure they are both positive, and equating them.
If you want to strictly follow convention, you would swap Tf and Ti inside the brackets and then put a minus sign in front of one of the Q's. This will give the same result (the two minus signs will cancel out).
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
